Cal Hypo induced cloudy water
meihobo
0
4
Melbourne Beach, FL 32951
Switched from liquid CL to Cal Hypo 73% and water has become somewhat cloudy (white).
11kgal plaster. Cartridge filter.
per Taylor K-2006
pH 7.4
CL 5
CC 0
TA 120
CYA 60
CaHardness 280
Borate 50
Have initiated shock CL 26
plan to continue SLAM
Will liquid CL slam clear up water?
Do I need to lay off the Cal Hypo forever? (have 50 lbs !!)
Any advice/comments appreciated.
Cloudiness is from scaling that is typical with cal hypo because it can strongly raise pH. Also your TA is too high.
You need to lower TA and pH to use cal-hypo and I would suggest pre-dilution in a 5 gallon bucket and then broadcasting it around the pool perimeter or pouring in front of a fast moving return.
It is a common problem with cal hypo to have water cloudiness for 24 hours after application.
