Ok so through my research on this site if i am correct i read it is not the chlorine level that gives you red and burning eyes its the PH level. Well ever since i switched to salt water we all have burning red eyes every time were in the pool. My ph stabilizes at 8.2 so im constantly adding muriatic acid to being it down the 7.2. Then repeat when it reaches. When the pool was liquid chlorine pool i kept chlorine at 3ppm. Now thats its salt water its 6ppm. I try to keep my chemicals to water this forum says. So what can i do to stop this? Not sure where my signature is anymore but incase this info is needed.... 20k gallon plaster pool, pentair vs pump, 36 de filter
Chlorine 6
Ph 7.6
Ch 350
Ta 110
Cya 50
Salt 4200ppm
Chlorine 6
Ph 7.6
Ch 350
Ta 110
Cya 50
Salt 4200ppm
