Hi,
Our pool hasn't had much use at all this year but I've maintained it. I am vacuuming my pool to close. I discovered a 4 inch round-shaped bulge on the pool bottom, about 2 feet away from the walls. We had our liner replaced last year so it's only 1 year old with hardly any use. The ground has settled (sand underneath) and there are more floor wrinkles than there were after installation last year. There are no trees around. Could a mole/volve cause that?
Regardless, the water is now 48 F and air temps are finally at freezing last night/tonight. (Yes I had pump running the whole time). I was going to suck it up and go in to try to flatten this bulge before closing. Would gently pushing the bulge down with my foot be good, or bad? Could it stress/damage the liner? Or should I just leave it? I don't want it to get even bigger, and have it burst the liner over the winter.
Advice appreciated - thanks in advance.
Kristin
Kristin
