Building in Georgia Drone PICS
propjetprop
104
Douglasville Georgia
Jandy 460 CartridgeFilter
Jandy 2.2HPVariable Speed Pump
Jandy AquaPure Integrated Salt System
Jandy LEDWhite Pool Lights
Jandy PS4Pool Control with iAqualink System (for use with iPhone, Android, MAC or PC
This systemhas a timer for every circuit, firmware to control variable speed pumps,built-in freeze protection for pumps, and the control, salt system, and circuitbreakers are all contained in one integrated box
Swim up bar with 4 concrete stools, baja shelf with umbrella holder, stairs.
6' deep end
Debating between Tahoe Blue Pebble Tech and the Tropical Breeze Pebbletech. The Tropical Breeze is a significant up charge.
Any advice or recommendations would be appreciated!
This is a shot from my drone. It might be a little too high.
I knew it was GA before I even looked at the location when I saw that red GA clay! That stuff will ruin a set of clothes faster than anything. Forget about shoes around it when it is wet. It will suck the shoes right off your feet :shock:
That is a great look set up.
Lets take a peek at your equipment....how big is your salt system? We suggest your get it rated at twice your pool size as this helps it keep up with the FC demands in the summer and saves the cell life.
With you having gunite it is time for your own set of links. I put these together for new pool owners. It is a lot of info so this will give you time to read it and start to learn it. Once you start using it eveything will start to click:
Print these out:
Bookmark these:
PoolMath
Make sure to ask any and all questions you might have no matter how small! We have all been where you are at one point.
This will also be a good time to ask your PB what test kit he will be providing. Let us know so we can fill in any holes.
Kim:kim: (LOVING the drone pics!)
How do I post more pics? I would like to update the thread.
And we would love to see them! As a new member, you're allocated x-amount of storage space for images. Just a fail-safe issue because of server space and the $$ required. So if you were to consider becoming a TFP Supporter, you would access to your own personal photo gallery with a fairly large allocation of space for image uploads. To see the benefits and comparisons, please take a peak at the link below in my signature listed in red. Hope to see a badge next to your profile someday. :)
Really want to see more drone footage too. I'm addicted to those things.
Here are a few more! Higher altitude
Yes... we are also on a septic system... so if you are searching the forums to see if you can do an inground pool with septic in the back yard, the answer is yes... you just have to be very careful!
