How 'bout a bump for this old thread.
I got a PM this weekend asking about my setup. I didn't realize I never followed up on it here.
After almost a year I have had only one minor problem with my setup which I half expected from the get go. I read about all the issues people have with the Liquidator and just shake my head. I'd still go with a pump if it cost 3X what a liquidator costs instead of the 1/3 I spent on mine.
The hardest part is finding a good deal on a pump. I watched eBay for a few months and got a pump for about $35. This is a Rola-Chem pump that was originally designed to pump chemicals in to pools (go figure). A new one would run over $250. It has a adjustable timer built in to it. I have figured out where to set it for summer and winter and just gradually adjust it as needed.
I store the bleach in a 16 gal. barrel I got from work so it was free. If you had to buy one it would probably be about $75. It sits next to the pool pump which is shaded on all sides so eat and sun don't seem to be an issue. My original plan was to bury it to keep it cool, but it doesn’t seem to be much of an issue, so I haven’t been motivated to dig a hole.
I initially used a brass port to connect to the PVC. I was concerned that my dogs could potentially do something to break a plastic one. My concern with brass was that it would corrode. I switched the brass one out after about 6 months because it was corroding. The plastic one has survived the dogs so far.
I did not use a check valve and I don't think it is necessary. When the pool pump turns on, some water is pushed in to the tubing, but it's only about an ounce, so it's not an issue.
With a 16 Gal container, I buy bleach when I find a good deal on it. I try not to keep it to full in the summer to avoid the heat. When I add more it takes 15 seconds to dump it in. I do get the crystals that are fouling the liquidators too..... but they aren’t an issue with 1/2" tubing. :-D
Feel free to ask any questions, I'll try to keep up with this thread.
