Build Final Stage
A_Gent
5
Massachusetts
Hello - in the final stage of pool build. 16x32 rectangle vinyl liner pool.
The contractor has just installed the wall padding and we have noticed small wrinkles in the padding. Will these show through once liner is installed?
I suspect water weight will press them out but was curious if anyone has had any experience.
A,
Welcome to TFP and congrats on your almost pool! I see you've made a lot of great choices on your equipment (like SWG) already. I personally have no experience or knowledge about vinyl lined pools but I can ping a few people that should be able to help. @kimkats @Jimrahbe @cowboycasey Can one of you help this new member with a vinyl lined pool question?
Good luck!
Chris
Reactions: A_Gent
