KJB1
Similar to my wishes. 1st build is tough knowing what you want. I was on a budget too so had to cut some things out. My top wishes are:Things i would do differently/wish i've done.
1. I took pictures of everything, all the plumbing/drains etc, but i failed to use a tape measure. There has been a few times i wish i knew exactly where everything was.
2. Larger Baja shelf/area
3. return jet near the "baja" shelf since its only on 6" of water it tends to over power, i wish it was angled toward the skimmer.
4. Separate control for skimmer/drain. Since all we get is small dirt, brushing it toward the drain would be great.
5. Extra drain on pavers, with some of the heavy rain it would be helpful. I may need to do this myself later.
6. Be a little more picky on the tile work, they did a good job over all but the 90degree cut could have been better.
1. Salt cell (don't much care about automation other than running the salt cell.)
2. Tile work, mainly the contractor grouting between coping and tile and it all cracking. I used some polyurethane caulking but I shouldn't have had to touch it.
3. 2 skimmers with separate drain/skimmer valves would have been nice.
4. Sheer/waterfall. Never use it. Not necessary.
5. I still don't know what is the proper way they are supposed to seal the top of the skimmer throat. Between the plastic and the underside of the coping. I know it's not grout. I sealed that up with foam backer and polyurethane caulking also. Another thing I should not have had to do.
