This is normal with a solar cover, the bubbles, but not the soapy type. The warmer the water becomes under the cover, the more bubbles you will get. I have a SWG so definitely not the issue. This also could be from the bleach, but I get this from the cover once removed. If you have on every inch after one hour of removing the cover, then definitely the bleach.
