Bubbles: Seeing Bubbles the water exhaust ports
Bcorig
50
Chino Hills CA
Pentair Intellichlor IC-40
Inground plaster 15500 gallon pool built built 1993.
Intelliflo VF-3050 3HP, Pentair 420 Cartridge Filter installed 2007.
For the past month or so I see air bubbles emanating from the water inputs.
No leaks from the pump or filter dome, Air is not accumulating in the filter.
Is this a significant symptom? If so what are the potential implications?
My pool technician has a 2-3 week backlog.
Thanks
Intellichlor IC40
Your SWCG creates chlorine and hydrogen gas. The chlorine goes into the water instantly. The hydrogen gas comes out of the returns as bubbles.
Obviously I didn’t know that. But I should have.
After I had that Free Cl = 13 I dropped the IC40 to 10%.
After extensI’ve use it dropped to 2 so I‘ve been hammering it at 100%. It’s generating more NaOCl and more H2
Also checked CYA = 50 so I’m slowly increasing that
Thank you again.
Perhaps another tidbit for you...
When you dialed your IC from 10% to 100%, it didn't start producing "stronger" chlorine, or more bubbles. Just more often. An SWG produces the same chlorine at 100% as it does on any other setting, only the duration changes. Your IC cycles every five minutes. At 100% setting, it's making chlorine full time. At 50%, it makes chlorine for 2-1/2 minutes, then turns itself off for 2-1/2 minutes, then repeats. At 10%, it's on for 30 seconds and off for 4-1/2 minutes, etc.
The bubbles were always there, you just didn't notice them, because they were only coming out of the returns for about 30 seconds every five minutes.
Reactions: Bcorig
Both posts are extremely useful. I’m printing them out.
Thank you both.
Reactions: Dirk
