Measured pH again, still as red as it gets at 8.2+. My faucet water is also that high. I don't know if that's normal or not.
"Potassium monopersulfate (MPS or potassium peroxymonosulfate) is a non-chlorine oxidizer that will interfere in the total chlorine DPD test. Treating recreational water with MPS to remove bather waste can result in false high combined chlorine or total chlorine readings."
more info:
I may have to find some new reagent to add to neutralize the MPS reading. Great. I find some discussion here, but don't have more time tonight:
I have reread the sticky for chlorine in a spa again. If the CC is a result of MPS, then maybe all I'm really in need of is getting the pH down. It would be odd to have a bunch of gunk growing already after running Ahhsome several times and draining the tub.
Since my CYA is low, SLAM FC is pretty low (chart only allows for 20 CYA min, so I've gotta work with that for now) . I'll figure out how much dichlor to add, and hopefully get CYA up to the preferred levels in the process.The 1.5 cc is concerning - raise to slam level
FC/CYA Levels
& see if it goes away since you have purged recently. You may need to do this more than once. Use poolmath effects of adding to see dichlor’s effects on the ph to prevent lowering it too much. If subsequent slam fc rounds are needed you may need to use liquid chlorine instead.
The only additive I've added is the Leisure Time Replenish dichlor. Upon a little googling the other 85% of its volume includes MPS, which interferes with chlorine testsWith CC that high, unless it's a false reading from "additives", if you didn't have a problem you do now.
Muriatic acid works better than dry acid btw. Have you read the sticky?
You gave me the impression the tub gets very little usage, is this last post contradictory? Usage REQUIRES enough sanitation to overcome waste products. In theory, with zero CC, silver ion, ozone, and UV would keep it that way with almost zero residual CHL.
It's good you got the test kit. Since it's purged, hopefully all you need do is take care of that CC situation and get ph in a good range. Have you read the sticky?
more info:
Proper procedures and chem test for MPS non-chlorine with ozonator, UV, Nature2
My jacuzzi was originally UV and Nature2 and had no ozone. I had the ozone installed last week to reduce the amount of chlorine exposure. After reading so much about the dichlor then chlorine method I got pretty familiar with keeping sanitization levels sustained. Checking with the Taylor kit, I...
www.troublefreepool.com
