- Jun 24, 2021
- 16,150
- Vinyl
- CircuPool RJ-60 Plus
Bleach is 6%. Liquid Chlorine is 10% or 12.5%. About the best deal is the $5.50 liquid chlorine at Walmart.
No. Take these and follow directions...Just to "clarify" (hahahahaha), I shouldn't use any clarifiers at any point during this process? I mean, I can see the bottom now in the shallow end, the pool is basically blue - just VERY cloudy still and getting not-cloudy VERY slowly even at my 24 FC level, vacuuming once a day, washing filter, etc.
Welcome to TFP. (My nephew lives in BellinghamAnything else to speed it up? Summer is short in the PNW!!
Thank you!! Yes - B'ham is a wonderful place - with only a few pools so you're kinda on your own. I gotta check out Walmart and see if they have any deals - we don't have Menards.Welcome to TFP. (My nephew lives in Bellingham.)
Keep up with what you're doing. It will take time but is looking so much better.
We have Menards here in Michigan and the 10% is 4.99 per gallon, with 11% rebate after that.
Got it - do you mean a hose with some sort of chlorinated water? Don't know if I have that...You may have to take the robot apart to scrub it - algae forms a protective film against chlorine and sometimes needs a brushing
Can you use a hose spray on high?
It's safe to swim at SLAM FC levels. It's gentler than the water coming out of your showerhead or bath faucet.start letting the sun ease off the heavy chlorine so people can swim again.
Good to know. Everything I'd googled said not to swim in much above 5 FC. And def not above 9. I'm at around 12 at the moment but coming down fast with the sun these days...It's safe to swim at SLAM FC levels. It's gentler than the water coming out of your showerhead or bath faucet.
Looking Good!And...after 2 weeks, and 30+ gallons of chlorine we are looking really good. Gotta do my final tests for the FC drop and CC and then can start letting the sun ease off the heavy chlorine so people can swim again. But even having it look so good is great.
BTW - how do I get the residual algae out of my pool robot? Soak it in a tub of highly chlorinated water, or?
Thanks again for all!
Max
That's because everything out there does not look at fc to cya ratio levels. What is your cya?Good to know. Everything I'd googled said not to swim in much above 5 FC. And def not above 9. I'm at around 12 at the moment but coming down fast with the sun these days...
OOps! For all you Michiganders reading: Menards liquid chlorine is 12.5%.We have Menards here in Michigan and the 10% is 4.99 per gallon, with 11% rebate after that.
