- Jun 24, 2021
- 16,696
- Vinyl
- CircuPool RJ-60 Plus
Slamming on!!! 730AM FC was 20.5, that was after the MA dose at 730 last nite. Now its 930A FC at 20 and brushing/vac each timeSlam on!
Sorry was meant to say Mustard AlgaeWhy are you adding muriatic acid?
That looks like Live Oak pollen, do you have any Live oak or Pin Oaks close to the pool? I spend the early spring pulling that brownish yellow pollen out of my pool until the catkins finish droppingThis is minor compaired to when I started. It soft, cant hardly feel it.
This year is the first year I have experienced it. Not many live oaks if anyThat looks like Live Oak pollen, do you have any Live oak or Pin Oaks close to the pool? I spend the early spring pulling that brownish yellow pollen out of my pool until the catkins finish dropping
It will b tomorrowCan you show some better pictures of the stuff?
There are two types of mustard algae.
One type is the yellow dust that sticks.
The other type is an olive green/yellow/brown color that looks like sand accumulating on the bottom.
Two at 0 loss? EDIT: is your CC <= .5, and do you see any visible algae?1. I can return pool back to normal operation? Minus the fact that I have a high FC. (leave SWG off)
See above...2. Do one more OCLT tonight? And if passes I am done
