Brown Algae??? Dirt?
rmturner54
654
Waxahachie, Tx.
I have been battling this for a while. From the pictures the pool get this brown dusting on the flat surfaces (steps, seats and in the bottom along the edges. I brush it and vacuum and it will stay gone for a day or so. Brushes very easy like a cloud of dust. At first I thought it was dirt for the rain. But we haven't had any rain in over a week. My numbers look good. Cleaned the cartridge filter the other day and wow!!! was it brown.
FC 6
TA 80
PH 7.4-7.5
CH 190-200
Salt 2900
I plan starting a OCLT tonite.
Am I on the right track.?
An OCLT is a good idea. CYA?
Might just be very fine dust that settles before being filtered. I have to use my vac hose and get in the pool and pick it up as we get that fine dust too.
Just finished the OCLT. Evening FC 6.5 to 7, Morning FC 5.5
I brushed and ran the pool cleaner at least an hour before the preforming the OCLT. The flat surfaces were nearly clear.
This morning the brown stuff was already starting to show on the flat surfaces. So it looks like I will need to SLAM.
Reactions: JamesW and mknauss
The people who answer questions are volunteers.
If you find the site to be a good resource, please consider making a donation to help support the site.
Thanks.
Reactions: beeswax
Here is an update. I started the SLAM yesterday morning at sunrise. Checked the FC and dosed every 2 hours until sunset. Scrubbing and running the robotic cleaner before each dose. So thru the course of the day my dosing amount decreased each time. Last dose at sunset I made sure the pump was in manual and put in on the lowest rpm.
This morning at or about sunset 730AM inspected the pool. Noticed very minimal brown dusting on the flat surfaces. Did another FC tested, results was 19FC and added bleach to reach target slam of 20 FC. Put pump back to my normal RPM of 1500.
It is now 930AM and I noticed a more considerable amount of dusting, brushed and started cleaned. Checked FC 18.5. Added bleach to reach target of 20.
My question is this. Am I on the right track? Why did the dusting increase after I turned the pump speed back to my normal RPM? Am I experiencing a dirt issue more than an algae issue?
Could be some dirt/pollen. Once the OCLT passes over several days then you can assume it is all dirt.
ok....i missed that. so the extra FC wont hurt for now
What is done is done. Return to the normal slam process and SLAM FC target until you pass at least 2 OCLTs, your CC <= .5 ...then raise to Mustard level for 24 hrs.
It is really hard to tell the difference between dust (TX) and algae from your pictures. If your dolphin is picking up any material, can you post some pictures of the robot basket with whatever it is picking up? Is it gritty or soft? Post some pictures of what it is picking up would help...
This is minor compaired to when I started. It soft, cant hardly feel it.
