Yep ~ Bama gave me the courage to swap out those hoses with no manual.
Honest to Pete, when I did it I thought: I hope this
blows to smithereens ~ because I knew it wasn't working.
When it worked ~ I literally cheered, like a big nerd, in my yard ~ it was fun!
I am so very thankful ~ there are really no words!
I will bet you last year we could have had the sparkle I was looking for, but I attributed that to the initial and only dose of Pristine Blue.
I cannot explain how the water cleared some this year, guessing just keeping it at shock level even without proper filtration helps.
And last year we looked superb if you consider we had a non-functioning filter.
Guessing I could sweep last year because it was a fresh fill and I had no debris, over the winter we collected debris so that made the vac problem appear.
Backwash still has me stumped... I had backwash pressure it came out with what I thought was force last year, but now that I see it's actual backwash spray I didn't have the force. Now we BackWash! Capital B with Pressure. Nightcrawlers popped out of the ground last night like you can't imagine! When I saw them I knew we were in business. I also knew I had decent Chlorine levels
bodies everywhere!
Seriously I do thank you, it was frustrating knowing there was a problem, knowing I was being patient and diligent about my testing and not seeing results when I knew if everything was correct I had to see results.
Word of advice to those with pool equipment... make sure you have a proper manual. I knew what they gave me was garbage, I should have insisted on something that I could use to troubleshoot. What they gave me wouldn't even be a good start for a fire. I dropped the ball on that and it almost toppled me. Had it not been for this forum I would have had several hundred more dollars out of pocket in Clorox and service calls. So I really do thank you all and I will post when it clears ~ which can't be soon enough. This is the first day ever I have come to work and knowing without a doubt everything is finally coming together and working as it should at home. Awesome Feeling ~ thanks!
