I am looking to replace a couple broken ball valves. Only the handles are broken at the moment. I am pretty sure I can do this but was looking for some extra direction. Looking at what I have, I think I need to re-plumb most of the piping so I dug out the ground a little bit and noticed there the center line is only 1.5" while the outer two lines are both 2" lines.
I know that the left handle is to the vacuum and the right is for the skimmer but I do not really know what the center line is. Is the center line a drain? As far as I can tell I don't have anything else in the pool. Only one skimmer and one vacuum port. There is some black round things at the bottom of the pool but I haven't been able to confirm if there is any water flow through them when the pump is on(doesnt seem like it).
I have seen a couple recommendations to buy Jandy valves. I am wondering how hard it would be to potentially use a(couple?) multi-port value or if I should just replace each ball-value with one jandy valve or just a new ball valves.
Any thoughts/tips are welcome.
Thanks
Thanks
