Earlier in the week I added 5 bags of burnout from bioguard. Not using anymore. I did see a previous thread where a guy that did the same as me had a similar ph. I've turned my pool slide. Do I correct the ph problem now? My water is crystal clear that is what makes this harder. When the attached hot tub is running it is very irritable to eyes/throat. A couple people have talked about burning eyes.
I did not write 2 .... I wrote 0.2 But that is only if you use 25ml of water, which is not needed.Jblizzle, are you multiplying by .2 or 2 when you calculate your free chlorine?
Sent from my SM-N920T using Tapatalk
