I just received a new MX6 to replace a prior vacuum that was pretty beat up. I hooked it up exactly as instructed and exactly like the prior vacuum. Filters are clean, no debris, each section of the hose has suction, but there is absolutely NO wheel movement Unless I turn the RPM’s up well over 3000, and even there it barely moves. The manual says the filter can be set as low as 22 GPH, I’ve got it over 50. The settings I had it on worked for my prior vacuum which was way crappier than this one. I have a side suction/dedicated cleaner line and leave the vacuum in the pool; it’s on a timer to run nightly.
I read a closed thread regarding someone who had a new one & thought it spun “too tight”.:and they wanted to loosen it. Is that an issue with these? I went to YouTube university and watched all of the troubleshooting videos.
So WTH is wrong ? Please don’t tell me to change out parts, it’s brand new.
Argh! This is so aggravating.
thanks
thanks
