Hi all,
Have had some bad experiences with pool services so doing it on my own. Got the Taylor K-2006 testing kit and ran tests on my pool water yesterday around 4 or 5PM. In trying to determine FC I had to keep adding a bunch of the powder and still had trouble getting the sample to turn any shade of pink. when I finally got some pink I added two drops of the next reagent before the water turned clear which said there was .4 FC in my sample....but then the water turned pink again. Not sure if I'm doing the test right. My other results ended up being CC = .2 or .4 (can't remember off the top of my head), pH = 8 (took two drops of the reagent to get it down to 7.6), TA = 170, CH = 300, and CYW was less than 30 as I had all of my sample in and could still see the black dot. So there is a lot of algae and dead algae at the bottom of my pool already (why I had to stop the pool service I had as they couldn't seem to clean it) so it makes sense that my FC and CC are so low. Also it seems that the TA and pH seem to go hand in hand with each other so I'm thinking I did those right. At this point I'm kind of confused as to where to go. I'm thinking I need to SLAM my pool in order to kill all the algae in there currently, but where to go after that I don't know. One other problem is apparently the dead algae and slim in my pool was too fine to get filtered by my cartridges so I bout some First Aid (I think is what its called) in order to get that filtered out, but I haven't added any as there is new algae growth. A pool supply company suggested this First Aid stuff to help clear up my pool, but I don't know if it will work. I'm not sure I calculated the total gallons correctly. I took four measurements of the width in different areas and then averaged that out. Took the length from the farthest point to the corner by the steps and then took an average of the depth. My pool is about 3 feet by the steps and then drops to about 5 feet in the middle before dropping down to about 12 or 13 feet at the deep end. Any suggestions or tips or guidance on anything I have done would be greatly appreciated. I have attached a picture of my pool.
