Just filled the new vinyl pool up (15,300G) salt pool. Added ten 40lb bags of salt and 2 6-1 shock bags (1lb each). Brushed salt in good first then shock at night. Woke up to a very clear but green pool. I am still waiting on Taylor test kit so had to go to local pool testing facility. Pump was running but not the chlorinator
Results:
Copper 0
Iron 0.2
Total alkalinity 298
pH 7.9
Chlorine shock 0.26
Free chlorine 0.26
Combined chlorine 0
Cyanuric acid 5
Calcium hardness 0
Phosphate 1,701
Salt 3,650
Pool store suggested 2 gallons muriatic acid
4 lbs shock
Our local water is generally very brownish/green from start. The chlorinator is now running, I set it the the highest 24 hour setting to start. Wondering if their advise seems correct as I’d like the swim this weekend. TIA.
Results:
Copper 0
Iron 0.2
pH 7.9
Chlorine shock 0.26
Free chlorine 0.26
Combined chlorine 0
Cyanuric acid 5
Calcium hardness 0
Phosphate 1,701
Salt 3,650
4 lbs shock
