Hello all,
I read a ton on this forum as we were trying to decide on the material for our replastering, and we decided to go with Quartzscapes Super Blue (in case you're not familiar -- this is a white base with blue and grey specs).
We went with a reputable contractor, listed on the NPT website, and they finished the job a few days ago.
As they were finishing plastering, I noticed that the entire pool looked blotchy. The blue/grey specs of the quartz were showing very little and there were areas where it looked plain white. I brought it up and was told that the specs will show up a lot more after the acid wash, which they were planning to do a couple of hours after wrapping up.
They acid washed and more specs definitely showed, but the blotchyness still looked the same. Almost as if someone was using a spatula to do the pool and missed some spots.
I brought it up again, and was told that it's because of a white powdery substance that comes up when doing Quartzscapes -- and that it will go away when the pool fills up and everything will look consistent. It didn't.
The last thing they said is that they're sending someone to brush and balance the pool every day for the next week or so, and that will do the trick. They said that all of this is perfectly normal. I cannot imagine that this is true. However, even within this forum I see people talking about this. And I looked at NPT's Facebook where they show off "great installations" and I'm seeing that they are also somewhat blotchy.
Blotchyness is hard to see due to lights/reflections or angles of photos, but I think I did a pretty good job in taking photos that show it.
A few notes:
1) When it's sunny, it shows much less.
2) In the main pool it's less visible. Not because it was done better, but just because the main pool is deeper. The bench of the main pool looks bad too. But the part that looks the worst is the jacuzzi.. because it's all a bench and shallow, so there is no water to hide the imperfections.
3) They are now claiming that it will all match at the end but it takes about a month.. I somehow doubt that.
I took several pictures in hopes of hearing your opinions (some drained - others filled). As far as I'm concerned the jacuzzi looks like a mess. I would never look at that and think that it looks brand new. The main pool is a mess too (if you are paying attention to the floor) but I can live with that because if you don't pay much attention then it looks good.
What do you think?
Thank you all in advance!!!
A few notes:
What do you think?
