Does this work? Thats a link to my pool from the Pool Math Ap.
FC 3.5 (dropping steadily from the crazy high when she dumped tons in)
CC 0
pH 7.5
TA 90
CH 100
CYA 10ish? The test water is foggy and I almost couldn't see the dot when the tube was all the way full. So there's some, but less then 20
Salt 3400
1. Can I change the pH target value in the app to 7.5 instead of 7.6 so it will agree Ive made my target? My little test thingy doesn't have 7.6 on it. Or is there a more precise pH test I should be using? Im using the two test one that has the chlorine on the other side in the tf100 kit.
2. Am I ok to skip adding calcium for now? I am fiberglass
3. Salt is OK to get the salt cell running when these guys show up now, right? I have a Hayward and their website says works best at 3200 and works between 2700 and 3400. Its been 48 hours since it was added.
ACTUAL Big Question I came to ask:
4. CYA. We told the pool store to order us some liquid, but I have no idea when that's going to show up. They don't stock it here. I have the dry kind from Lowes. The app says to add 11lbs. I THINK Ive read I should NOT add the whole amount at once and sort of sneak up on it, right? So ... how much and how.
When it says add to sock does it mean a human sock or a skimmer sock? I don't have any skimmer socks. It means a human sock right?
I have little feet. I can maybe get half a pound into my sock. I need "explain it like I'm 5" directions on how to get that number up.
