I literally pulled out the previous heater and put in the exact same model... with all the same connections and everything
I don't know the capacity rating, however along the same lines, i've had this exactly same make and model heater working properly installed here for the previous 7 years. I have changed nothing about the original install except hooked up and new heater the exact same way than before.I see a flexible gas line leading to your gas regulator.
The Installation Manual says "The use of Flexible Connectors (FLEX) is NOT recommended unless they are properly sized according to the supplier recommendations for the heater rating."
Do you know what the capacity rating of that flex line is?
When i first power it on its says ERR AFS, then when i turn the heater button on it switches to ERR AGSWhat is the error code?
Well James. You are 100% correct. Pool place said it requires 220 and this is fed by a 20 Amp 110.The fan sounds too slow, which is usually due to the supply voltage being 120 and the selector plug is 240.
What is the circuit breaker for the power going to the heater?
Do not switch to the 120 plug unless you are 100% sure that the supply voltage is 120.
Welp that was 100% the problem. I had the 240V pigtail plugged in and my old one was running on 120.
