I am happy to take any and all suggestions!! I just flat ran out of room. I purchased this shed when I had the much smaller Intex filter/swg. I need a bigger pool shed now!Just tug the clear cover slightly to the left when opening. My setup is exactly like yours, no issues. You are an official PVC design and installation expert.
OK perhaps you should have rotated the access to the top of the flow switch away from the wall but thats from my hypercritical observation.
That's what I do, and you better enjoy that pool now, you deserve it!!!!!!!!!Just tug the clear cover slightly to the left when opening.
That switch looks overloaded. Does it have a rating label somewhere on it saying its max current handling capability? I’m guessing is max 15A.Holy Crud!! This can’t be good
This is the plug to my pump. It was plugged into a timer that I can control from my phone. The pump was running when I found this, but the timer was offline. I’m thinking there is no way to fix this myself. ??? I’m in Missouri, I’ll buy an airline ticket,.. helpView attachment 345171View attachment 345172
yes,.it is a 15A. What should it be?That switch looks overloaded. Does it have a rating label somewhere on it saying its max current handling capability? I’m guessing is max 15A.
And are the pump and new SWCG on the same plug?what does your pump say?
It’s also 15A so no headroom on the current capacity. You should change to a 20A switch if available. Might also want to check the rating on the outlet of what it’s plugged into. May be good to upgrade it (and the wiring supplying it) to 20A.The pump and SWG are on separate plugs and timers. View attachment 345194
