- Aug 20, 2020
- 6,163
- Plaster
- CircuPool RJ-60
I nominate you for the Trouble Free Pool DIY project of the year!Today is the day. Excited!
I like the special “suits” made of trash bags and duct tape. I can imagine that stuff getting into every crevice of my clothing.
Appreciate the sentiment, but the only thing I’ve done myself the past couple weeks is write very painful checks.I nominate you for the Trouble Free Pool DIY project of the year!
The trophy is a little guy screaming 'THEY WANY HOW MUCH???????'I nominate you for the Trouble Free Pool DIY project of the year!
That looks like light on the front of a freight train.
THERE IT IS!!!!
Yup, at the other end of the tunnel!That looks like light on the front of a freight train.
EXACTLY! But it will be okA leaf and some kind of berry or acorn sunk to the bottom and left a little stain. I can totally see how little things like that would drive people nuts where before there was so many stains and discoloration that I didn’t even notice.
Diamondbrite plaster. I think it’ll be ok. I’m still used to seeing the bullfrog shaped stain left a couple years ago from a large frog that got under the cover over winter. When I tried to scoop it out with the net the body just dissolved into nothing. Was the weirdest thing I’ve ever seen, well maybe not the weirdest thing.Sorry, can't remember, plaster or pebble finish? We have mini pebble, have lots of trees. Have had a few things leave a stain on the bottom. Within 3ish days, they are gone. So I guess they are tannins that the balanced water help to remove.
Fingers crossed for you.
-Tom
Yes, that’s possible but they appear to be well sealed. A dye test can be used to check though.Process of elimination works
Don't forget the possibility of the skimmers themselves.
I'd seal the plumbing in stages per the plan, and then explore further if need be.A dye test can be used to check though.
