Hi TFP, new to the boards.
Bought a house with a pool a bit over a year ago, things have been going great, just catching up on some points I am a bit confused about and believe this is the crew that can help me out.
1) I have 2 skimmers and 2 'floor drains' (not sure if they are actually drains, I don't see anyway in the system to actually "drain" the pool through them. You can see on the pad, I can switch the flow from the skimmer into the pump to #1 or #2, but no 3rd valve to control those bottom drains. There is the spigot on top of the pump plumbing, if they water is high I can pump water out of the pool, but I assume if that water level was below the skimmer line, I would actually not have any way to get water out of the pool, without putting some sort of external sump pump in the pool.
My question is - based on the below, any way to help me identify the purpose of those 'floor drains' - and beyond the spigot / external sump pump - any other way you see to be able to drain the pool (not that I need to know) with my current system?
2) my other question is more specific to the skimmers - in Skim #1, I have an open pipe generally above the water line. Is this some sort of small overflow drain? And if so - where do you think that goes to?
In Skim #2, you can see there is no open pipe, it is actually closed off. Not sure what that is for?
Thanks in advance team!!!
