Moved from here.. Boric Acid the easy way
I too took a look at the insecticide boric acid stuff. Be careful and read the fine print. I nearly bough 50lbs of the stuff, but went back to read all the details as I hadn’t stumbled across this thread yet and thought it odd that nobody was talking about using the insecticide stuff if it worked and it was cheaper. Turns out the stuff I was about to buy had a blue dye added to it so you can see where you’ve sprayed it as a bug killer. I’m not sure what the dye is made of, but I don’t suppose it’d be a great addition to your pool.
