Booster pump not running
Jun 5, 2016
14
Murphy, TX
I have a Pentair LA01N booster pump that runs my Kreepy Krauly cleaner. I noticed the other day that it isn't running. When I try to kick it on it hums for 15-20 seconds, then turns off. Any suggestions as to what the failure is & how to fix it? I'm guessing a bearing, but that is just a WAG.
TIA
Probably time for a new motor or pump.
Motor cost is about 2/3 the cost of an entire pump. I would just get a new pump for around $300.
TIA
I have the exact same issue. The pump hums for 5-6 seconds and then stops. If I keep the switch on, it tries again after a few minutes, hums for 5-6 seconds, and then turns off again.
Two questions:
1. Did you find a to-do guide to test and replace the capacitor?
2. Since it was not the capacitor, did you figure out the real issue? What was it? How did you did it?
Thanks.
