Unfortunately no. Many installers do something like that at the pump or filter, then later you are hosed and have to cut the line to unscrew something.Is that fitting supposed to unscrew from the outlet?
You’d cut at the blue and build back from there. Edited to add, it will thread out of the pump once you’ve cut loose.Ok I think I'm with you @Lake Placid but just to be 100% clear cut at the red line or at the blue? I'm not professional (obviously lol) so behind the 90 to me is the red line...
Pat, he might be asking if the PVC is supposed to unscrew out of the pump. In other words, are the pump's ports threaded?Unfortunately no. Many installers do something like that at the pump or filter, then later you are hosed and have to cut the line to unscrew something.Hence .... the union later.
Yah, that's a lot of stress on that joint. Not just the vibration, but that connection is probably holding the pump in place, like keeping it from sliding around. Job one is to attach it to the pad. It'll have mounting holes for that purpose. Is it sitting on concrete? You'll need a masonry drill bit and some sort of masonry fasteners. There are lots of varieties of those. Pick out the fasteners first, and their packaging should spec the proper size of the drill hole.Yeah it's not bolted down so you're probably right the vibration caused this...
Pipe nipple extractor set will aid in removal if you want to spend the $15 on it. Might find cheaper at harbor freight, although you’ll need to buy the tool to fix that tool at the same time.Yep lots of stress at that point. As soon as I cut and tried to unscrew the joint it came down clean as if it was cut... Removing that it's going to be fun without messing up the threads.
After reading @Dirk post, I looked back at the pic. Is that galvanized pipe? Ugggh, you know there’s another can of worms in that connection if you breathe on it wrong. Whoever did that work brings emotions….well let’s just say the adjectives “throttling“ and “inch of their life“ comes to mind.PS. Do look into the flex hose. There are kits you can buy that include the hose and the fittings. A local pool store might have one, if you have to get this back together today. And I know you've already entertained the idea: now's the time to address the other connection, too. My favorite axiom: "Do it right, do it once."
Exactly my thoughts!After reading @Dirk post, I looked back at the pic. Is that galvanized pipe? Ugggh, you know there’s another can of worms in that connection if you breathe on it wrong. Whoever did that work brings emotions….well let’s just say the adjectives “throttling“ and “inch of their life“ comes to mind.![]()
Oh so you too have achieved Doctoral Degree status in the law of the Irishman. Good day fellow Dr!Exactly my thoughts!It's possible just the wiggling of fixing the top connection is going to mess up the other one. Of course, Murphy's Law dictates it won't give way until you have the other one all put back together, and it's a weekday morning.
