The reason for the delayed finish is because I hit a snag with the pool company I chose to hire the first go around, (PM me for the company name if you are in my area). The contract stipulated that an acid wash was to be completed before the bond kote, and the middle man PB tried to cut corners by not requiring the sub-contractor to acid wash. I asked them to do it, and they then did a very diluted rinse, using less than one bottle for the entire pool. Also, the sub-contractor did a very diluted coat with the bond kote and did not mix to the instructions on the bag, I did not realize this at the time of install. Lastly, there was some argument to who damaged the hydrostat in the deep end of the pool, and we "mutually" walked away from each other. I am still working on a chargeback / acceptable refund amount as the company is trying to profit off their shoddy work.
The biggest negative here is that I have a diluted layer of bond kote on essentially a pressure washed old plaster surface. The bond kote has been baking in the sun and potential creating bonding issues, and now plaster companies don't want to warranty work they didn't prep for. I am hoping that come plaster time I won't have hollow sounding bond kote, but this could potentially end up costing me a chunk of money in the longer term.
I have already lined up a new company to do the plaster, and was told this morning that it will be done later this week or next. I have installed the transition tiles on the steps in preparation for the plaster also. I used the same Laticrete 254 to create a mud bed for the tile. And yes, I need to scrub/sand the coping where it has gotten dirty.
Some lessons I learned during this process that I wish I had done differently:
- After old perimeter tile was removed, I should have cut the plaster where the bottom of the new tile would rest, and then chipped up to that line to allow more room for plaster. Now the risk of damaging the newly installed tile is not worth taking, and as such my plaster won't have as much grab.
- I wish I had put a thin layer of grout/mortar or whatever on the face of the bond beam to smooth it out before installing tile so that I could have achieved a more uniform tile.
- I probably should have left a bit more room between the coping and where the tile meets.
- Lastly, I should have probably chosen a slightly shorter coping so that I didn't have as much overhang into the pool. In some places however, this would have created a larger epoxy gap.
Will update final pictures after the plaster is in.
