Bond beam repair
Davileet
69
Gainesville, VA
I too am using Laticrete 254, picked it up today. Between the hydro ban, mortar, and grout I spent $1k. It seems that in order for my coping to be level with the deck, I will be using 1/2"+ of mortar. I guess the alternative would have been to raise the bond beam higher than it originally was.
jimmythegreek
In The Industry
Aug 10, 2017
2,132
Morris Cnty NJ
That's not bad its better to stay low and mud it up. Easier to add mud than grind and chip away concrete. The good materials are pricey but they last indefinitely. An average coping job is 4 to 5k alone
Reactions: Davileet
Davileet
69
Gainesville, VA
There is two spots in my bond beam that are pretty high, and when placing a coping on top its almost flush with the deck without any mortar. What is the minimum amount of mortar you recommend? And should I plan to chip or grind the bond beam down in those high spots?
jimmythegreek
In The Industry
Aug 10, 2017
2,132
Morris Cnty NJ
Normally I'd say grind it down. If you can get a solid clean pass of thinset under the coping it will hold. 254 is crazy strong stuff the coping will break before the mud will. Yiu could always take a grinder and make a divot in center to have a little spot of thicker mud. When grouted coping gets very strong it bites to the next pieces as well
Reactions: Davileet
Davileet
69
Gainesville, VA
Thank you. I will go ahead and chip them down a bit. I put hydroban on the high spots already, but luckily I have more to spare. I purchased about 1 bag too many unfortunately.
Davileet
69
Gainesville, VA
Easiest way is to take a grinder and make parallel slices the same depth and just chip them right out. Keeps you from making a mess it's a controlled mess
That is a good idea. It's funny I hadn't thought of that yet, cause I actually ended up having to do that to remove some excess material that pushed out the concrete form a bit. Tomorrow is the big day of dry setting the coping, and hopefully moving on to installing them.
Davileet
69
Gainesville, VA
Got all the coping stones dry set. Will be putting them in permanently tomorrow. Wasn't terribly difficult honestly, but I think that may be attributed to my particular measurements I took.
jimmythegreek
In The Industry
Aug 10, 2017
2,132
Morris Cnty NJ
I use type S mortar for grout. I just tint it if I need it a different shade. I always seal the coping before grouting you can easily leave stains and residue on them. I would recommend sealing them especially with that lighter color. The coping looks great and well fitted btw
Reactions: Davileet
Davileet
69
Gainesville, VA
Spill it!! How did you measure those?? You have some mad skills!!! WOW!
I bought the coping stones from a company called Federal Stone. I had to purchase a measuring chart from them, which is basically just plexiglass with lines that have different radius markings on it. Here is a video showing what I am talking about. Video Link
As for placing the stones and cutting them, I put full pieces in where I could, and where the radius changed a bit and a cut piece was needed, I would put the stone to be cut on the bond beam, and overlap the neighboring stones on top marking a 1/2" over for the cut line. I had a stick that was cut to 1/2" thick to act as a grout line measurement tool I would fit in between stones, and also used it as a marking tool.
Davileet
69
Gainesville, VA
Thank you. I do feel the stones turned out better than my initial expectations.
Federal stone actually does not recommend using a sealer it seems. From their website -
"The stones will come from Federal Stone® without a sealer applied. Since the stones are porous and will be set in a wet mudbed, the mositure needs to be able to work it's way out of the stone. If the stones are still hydrating when a sealer is applied, the moisture could get trapped inside, causing a discoloration to the stone. Further, placing a sealer on top will in turn cause a maintenance issue due to re-application. If a sealer is imperative, then just make sure it is water based because an acrylic sealer will cause a slip concern."
Do you think a sealer is imperative? If so I can always get a water based sealer as they suggest.
Davileet
69
Gainesville, VA
https://www.lowes.com/pd/MAPEI-Larg...hite-Powder-Thinset-Medium-Bed-Mortar/3743785
Would something like this work you think? The only type s mortar I can find is gray, and white is preferable for sure.
jimmythegreek
In The Industry
Aug 10, 2017
2,132
Morris Cnty NJ
Dont use thinset. It wont hold up. Ne aware light colors get dirty easily. I only use water base sealer unless I need a darkening then I use dual guard which penetrates and gives wet look. You dont have alot of joints. Just carefully tape off each seam and add a foot of plastic to ne safe on either side. Grout and then get it looking good sponging and tooling the joint then pull tape. No issues and easy on large format coping. If you use grout make sure its exterior rated and go back and seal it especially with a light color. Same deal tape it off
Reactions: Davileet
Davileet
69
Gainesville, VA
So should I be using a gray type s mortar? I was just assuming since the coping was white, I would be using a white grout. Which sealer do you recommend?
jimmythegreek
In The Industry
Aug 10, 2017
2,132
Morris Cnty NJ
Grey type S is a standard grout for coping. You can use whatever you prefer. Any tile grout has to be outdoor rated it will be polymer fortified for strength. Not much difference in sealers I use pave seal only because my supply house carries tons of it and they have the full line. For tile grout sealer find one that's outdoor rated
Davileet
69
Gainesville, VA
Does Laticrete make a good product to use as grout for the coping? I haven't quite gotten to the point where the coping needs grout, but possibly tomorrow I will.
