I am trying to remove the WhisperFlo Seal Plate from the old motor (to be replaced by a new motor). It is held by four hex bolts. I easily removed three of them but the fourth one is stuck. Any advice on how to remove it? I tried spaying it with WD-40 but did not work.
Also I am thinking of replacing all of the bolts, washers and nuts (the ones that attach the volute, seal plate and motor all together). However, adding up all the official hardware is expensive. Each bolt and washer and nut costs several dollars if purchased as a Pentair Part yet they all look like standard hardware parts.
Can I just buy and use Home Depot hardware instead? (I am thinking there is nothing special about the Pentair hardware vs Home Depot hardware).
Thanks!
Thanks!
