Hi guys:
I have a TF-100 test kit. Here are my reading...
FC-4.0
PH-7.6
TA-60
CYA-less than 20 (black dot does not disappear completely)
Water Temp -87 degrees
My water is pretty blue and clear however I have these green stains along the vinyl liner in multiple spots that are hard to remove. They are very faint green.
I vacuumed and back washed and rinsed my sand filter.
I am assuming this is some form of Algae ?
I am prepared to SLAM if needed. I know I need more CYA but don't want to wait days for it to dissolve in skimmer sock (seems to take days)
As you can see my pool is pretty blue, the stains are hard to see.
Thank you all in advance for your advice.
On a side note, I am awaiting my Dolphin S200 so I hopefully don't have to vacuum anymore.
Also, if the CYA is less than 20, what is the harm in starting slam now ? I understand it has to be raised, but not sure why it needs to be prior to slam.
FC-4.0
PH-7.6
TA-60
