Hello, new to the forum but have had a pool for about thirty years/ Above ground, vinyl 24 ft round. using Taylor Complete FAS_DPD Chlorine kit to test and stopping by pool store once in a while to check their results to mine.
Here are my results:
CC 0.6
FC 0.6
pH 7.3
TA 140
Cyuranic Acid 86
Hardness 170
We have copper and iron in the water. I have test strips and this is verified by the pool store.
Filter had been running 24/7 since June 1.
I did a slam about 2 and 1/2 weeks ago using chlorox bleach. Definitely had algea prior to the slam. During the slam, it rained every day but I kept testing and keeping the chlorine high and adjusted for the Cyauranic acid being high. We also added Bioguard Algeacide and Sparkle Up
After the slam, when I would add either Borax or Muriatic acid, within minutes, white stuff that looked like wet tissues would come on the top of the pool and take an hour or so to disappear. The pool store said it was a resistant mold or algea and to add more algaecide.
I've also added Bioguard Mineral Magnet-about 8 bottles total since opening. We add Sparkle up periodically as well.
Last Tuesday, the pH was low so I added Borax and immediately the pool turned brown. I thought there was enough mineral magnet but I guess not!
On Thursday, I added 2 bottles of ascorbic acid per directions for my volume and then more Mineral Magnet. I added 4 cups Sparkle up to the filter. The pool was beautiful blue in less than 2 hours. All the stains were gone. I watched a video and it per that recommendation I've kept the CC around 1-2 since then. On Suday night we did a filter clean out.
The pool is magically now a beautiful blue but you can only see to about 6 inches from the bottom. It has rained off and on here since the beginning of June.
So, finally to my questions:
Does anyone know what the white tissue floating on top is? We have a sand filter so it's not DE and the pool store has no clue.
Second, how do I get rid of the white cloud in the pool without precipitating metals again?
I tried to be very thorough but may have forgotten some chemical additions. I've been so obsessed with this and would just like to get it cleared up and also stop spending time and money at the pool. Thanks, everyone in advance for your input!!
CC 0.6
FC 0.6
pH 7.3
TA 140
Cyuranic Acid 86
Hardness 170
