Note that any procedures have costs and risks.
Do your own research to make sure that you understand the costs and risks.
I recommend a local professional to help you figure out the best solution for you.
Everything is at your own risk based on your own research and your own decisions.
I would try Jack's #2 (Sulfamic acid) followed by a drain and refill
if it is safe to drain.
You can do a light acid wash after, but it is better to avoid acid washing because it damages the plaster.
Plaster is made of cement and aggregate.
An acid wash will dissolve the cement and expose the aggregate.
If the aggregate is quartz sand, the surface will be like sandpaper.
If the aggregate is pebble, the surface will be like exposed aggregate concrete.
There are different types of pebble from small and smooth to big and rough.
Some people find it objectionable and some people are not as bothered by it.
I would avoid an acid wash if possible especially if the surface is now smooth.
I would try sulfamic acid first and then a no drain acid wash before doing a drain and acid wash.
Even if the sulfamic acid only gets 50% of the stains, it will reduce the amount of acid required for the acid wash.
Don't allow the sulfamic acid to circulate through the system.
Metal items in the water, like lights, rails and light niches can possibly be damaged by sulfamic acid or a zero alkalinity treatment (no drain acid wash), so rails should be removed and lights can be pulled out and put on the deck during treatment, but niches can't be moved.
In the below case, they opted for a drain and acid wash, but that causes a lot of cement in the plaster to dissolve, which damages the plaster.
The people were happy with the appearance, but they never reported on the damage to the plaster or if it got really rough.
Hi, Everyone! New to the forum and to pools in general. Closed on a house with my first pool! Yay! Although it's only two years old it has major discoloration (light and dark spots). General home inspector thought it was algae but the water is so clear. Here is what the prior owners...
www.troublefreepool.com
jacksmagic.com
