- Oct 25, 2017
- 604
- Plaster
- Jandy Truclear / Ei
Hi guys. Ive neglected my pool for about a year. Fortunately its still clear, but Im afraid I have some black algae. Black spots at the bottom of the pool, when I scrape them off they are dark greenish. Ran my tests, but my chemicals are over 2 years old. Ive ordered new, and they'll be here Thursday. And to add to my pool woes, the numbers on my SWG and pump have faded out, so I cant see where the pump and SWG is set at.
My CL level is 4, so Im assuming the SWG is doing its job. CYA is negligible, so I added a sockfull yesterday. CH is 300, TA is 70, so Im in the ballpark there. I know I need to get the CYA boosted up, but with me having to run the CL high because of the black algae, should I keep CYA at a lower level? If I boost the CYA to 40, I will have to set the FC between 7 and 16 to battle this black algae. At 40 its lower than recommended, but higher will mean a higher chlorine level for a while until I get this algae under control.
Thanks.
Thanks.
