- May 3, 2014
- 62,752
- Fiberglass
- Pentair Intellichlor IC-40
With a proper test kit run the pH, TA, and CH tests on your fill water.
Once the pool is full, run the pump for several hours and then test for FC, pH, TA, CH, and CYA.
Post them up. If you drained completely you will need chlorine and CYA immediately.
