My pool was recently refurbished with a PebbleTec (PTI) PebbleFina finish. While I want to maintain the chemistry within the PTI recommendations as much as possible, I travel a bit and am trying to figure out how to manage chlorine levels while I'm gone. I use Pool Math 100% of the time (I love that I can click on the CSI "tab" and play with the numbers and see what effect any/all changes will have on CSI before I do them!). I use a Taylor K-2006C FAS-DPD test kit. I use liquid chlorine.
My goal is to honor the PTI recommendations as much as possible (warranty). I'm just trying to figure out the best way to maintain sanitizer levels during times of travel. I sure appreciate any/all input.
Mark
- My pool uses around 2-ppm/day Cl. Do high FC concentrations have a deleterious effect on plaster? I'm considering jacking up my chlorine to, say, 15-ppm when I go out of town to last me a week. Unintended consequences?
- I'm also considering restarting my SWG. I'd have to elevate my CYA to around 50-ppm. Would there be any problems with going back and forth between SWG and liquid chlorine?
- If I run the SWG and the chlorine levels are not within TFP range, is there any problem with augmenting with liquid chlorine while the SWG is running?
Chemistry | pH | TA | CH | CYA | CSI | FC |
My Pool | 7.7 | 60 | 400 | 40 | -0.06 | 4 |
PebbleTec (PTI) Rec. | 7.2 - 7.6 | 70 - 100 | 150 - 300 | 20 - 30 | -0.3 - 0.3 | 1 - 3 |
Mark
