- May 29, 2021
- 7
- Vinyl
- Autopilot Digital PPC1 (RC-35)
I have an Aqua-cal pool pilot digital nano running at 65% output. I need to increase by chlorine level. Because I'm cheap, I currently run the pump for 10 hours at 2600rpm, which is just enough for the digital nano to generate chlorine, anything lower and I get flow errors on the display.
Should I increase the output of the SWG, presumably decreasing its lifespan, or run the pump longer?
Thoughts?
Thanks!
Thoughts?
Thanks!
