Best pool heater pump
Sep 4, 2015
16
Ca
Good afternoon,
Looking to add a new pool pump heater to my existing Pentair pool equipment. My pool is 17' x 36' and roughly 20,000 gallons.
Equip. Easy touch panel ,VS pump ,Intellichlor, and Filter.
Thank you
If you are going to heat the entire pool then a 400,000 BTU heater is best. Not sure if you wish to have a Heat Pump or a true Heater. Since you have all Pentair equipment then you can stay with that mfg. Raypak also makes a heater or Heat Pump depending on what your preference would be. A heat pump is normally all electric whereas a heater can be run by natural gas or propane.
