First question is rather easy. Can you give me some ideas for good, reputable, decent priced online pool stores. I've had about a 25% bad experience ordering things thru Amazon.
Second question. I've got a problem somewhere and I'm assuming it's a leak. Air builds up in my Sand filter. When I turn the pump off the air rushes back and I loose pump prime. I'm assuming what is happening is that I have a small leak somewhere and filter is not passing gas...see what I did there
Is this a typical problem and is there a specific place I should look for leaks? If not what's the easiest way to locate leaks? With a leak out it's pretty easy, I always use a spray bottle with soap and water to find car tire leaks. Not sure how you find a vacuum leak though.
Any help would be appreciated.
