I was inspecting my pool equipment - and I believe that my pumps are not properly bonded (actually not bonded at all). I moved into a house with this setup, I have some history from the previous owner that both the booster motor and main motor were replaced at one point in time.
Current setup looks like this, I will explain:
RED WIRE - coming off booster pump and is attached to a ground post under my SWG...
PURPLE WIRE - this was coming out of the ground I noticed and connected to nothing. I took the cover off the pump/motor connection and saw the bond post looks like it was never touched.
I have to assume that bare copper wire coming out of the ground next to the pad is a bonding wire, and when the pump motors (both were previously replaced I can see) were installed the technicians disregarded the original bonding and left me with what I have now...
My question to the team would be as follow, using this picture of what I think would be correct
***NOTE PICTURE REVISED IN COMMENT 3, no longer correct***
GREEN WIRE - run a bond wire from the booster pump to the main pump terminal
PURPLE WIRE - connect the loose wire from the ground to my main pump terminal
Does that seem correct based on the information I have provided? If so, my other question is can I extend the purple bond wire through some sort of terminal or splice to add length to it. Whoever severed that wire previously did not leave me with enough slack to reach all the way to my pump bond terminal. I would like to add another couple feet of wire to be able to do a clean install, any recommendations on the time of connection I can make on this bond wire to achieve this?
