I have been having bad experiences with my pool service companies so I am trying to do things myself. In the process of understanding water chemistry I was noticing some discrepancies in test results. I purchased a LaMotte ColorQ test kit hoping it would be easy and accurate.
In starting my learning I started by running samples to the pool store at the same time I ran the test to see if I was doing things correctly. I noticed discrepancies, so I took additional tests to other stores and the discrepancies continued. So, I got a little crazy and take testing to a wider scale... I decided to take samples to 3 different pool stores and run one myself (total of 4 tests) for two weeks in a row (8 total test).
Here are my results:
Week #1
Test #4 is me, the LaMotte ColorQ. Test #3 is a pool store, but they are using the LaMotte Waterlink Spin Lab. Test #1 and Test #2 are general pool stores doing it the more ‘old fashioned’ way by matching colors.
As for the high chlorine in week #2, I shocked it the prior week and still had not come down. I expect test #1 and #2 only read 5 because I think that is the highest level on their chart.
I followed the standard cautions in my personal testing as noted in the ColorQ test kit (take samples after pump has been on for awhile, not take sample near jet, fill properly, keep out of light, test right away, etc.
Alkalinity, CH and metal’s looks particularly off. Chlorine off quite a bit the first week, reading 4's in both pool stores, but much higher in LaMotte tests.
I welcome any feedback about what to think of all this. My initial (though novice) opinion is the high variation is troubling to me but there very well may be some good reason for it or perhaps the variation is not something I should worry about - though the results suggest different treatments to the pool. Thank you in advance for reading all this!
Week #1
Test #1 | Test #2 | Test #3 | Test #4 | |
Tot Chlorine | 4 | 8.22 | 6.69 | |
Free Chlorine | 4 | 4 | 8.22 | 6.69 |
pH | 7.4 | 7.6 | 7.8 | 7.6 |
Alkalinity | 120 | 110 | 94 | 80 |
Adjusted Alkalinity | 75 | |||
Calcium Hardness | 320 | 240 | 242 | 290 |
Stabilizer (CYA) | 100 | 90 | 58 | 91 |
Tot Dissolved Solids | 900 | 700 | ||
Phosphates | 100 | 0 | ||
Iron | 0 | 0.1 | ||
Copper | 0.5 | 0.9 | ||
Week #2 | ||||
Tot Chlorine | 5 | 5 | 13.67 | 9.2 |
Free Chlorine | 5 | 5 | 13.67 | 9.2 |
pH | 7.6 | 7.6 | 7.8 | 7.5 |
Alkalinity | 120 | 100 | 71 | 47 |
Adjusted Alkalinity | 48 | |||
Calcium Hardness | 375 | 200 | 288 | 316 |
Stabilizer (CYA) | 100 | 99 | 69 | 115 |
Tot Dissolved Solids | 1100 | 700 | ||
Iron | 0 | 0 | 0.2 | |
Copper | 0 | 0.2 | 0.8 |
