Hi all,
I plan to add borates for the first time, and I have a couple questions before doing this:
1) Does adding borates affect CYA? I'm going to use boric acid granules (technical grade) from DudaDiesel.
2) Do I add boric acid at all once? My borate level is currently 17, and pool math says I need 47 lbs of boric acid.
3) Does the boric acid get broadcasted over the deep end of the pool or across the whole pool?
I just added muriatic acid to lower my TA to 60 and pH to 7.2. I plan to test borates one last time and then add the boric acid.
Thanks for the help!
