Bearings for an Intelliflo 2-VST pump motor (Model 011055)
Larsslc
1
St. George, UT
I have an Intelliflo 2-VST pump which is getting noisy. I checked it closely and saw some water leak coming out the joint at the seal. This tells me the seal has failed and the bearing is starting to fail. I have looked all over the internet trying to find what bearing replacements I should use. I did find some bearing numbers for a similar Intelliflo pump (not model 011055). Does anyone know what bearings I should get (I know there are two different sizes).
mknauss
44,895
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Sorry you have not received any replies. I believe rebuilding VS motors is more involved than the old SS motors.
