BEARINGS and shaft seal Jandy pump
jazyje
0
Jun 17, 2016
34
Moorestown, NJ
Hoping to get help finding an online or local supplier for my pump - Jandy Pro Stealth 1.0 SHPF. Need new bearings and possibly shaft seal as well. (Anything else I should replace - I'm going to attempt DIY).
Really loud when started up this season... Can literally hear it 100 feet away. Sounds like there's a loose bearing in there.[h=1][/h]
You'll need a pair of 6203 double seal bearings. Specifically 62032RS, which has a rubber seal on each side. You can find those generically.
You'll also need a R0479400 seal if the pump is newer than serial number P08FF0001, or a R0445500 seal if it's earlier than that.
Thanks for quick reply! Do you think I can buy them at any electrical supply store or should go to a pool store? Is there a bearing puller you'd recommend?
OK, so the wet part has a serial #J06FH2106. But the motor is actually Century Centurion A.O. Smith serial CB07-27. Part 7-193993-05. I'm going to be replacing the parts inside the motor, correct? SO I should look for A.O. Smith parts? (sorry, confused).
If I were going to replace it, I'd go with a 2-speed model. You can look up either a SQS1102R or a B2982 motor and that will replace the one you have. Be aware that both of those replacements are 230 volt only. So, if you're running 120 volts to the pump that may not be an option.
