I'm currently leveling the ground and then I plan to add a 2" base surrounded by landscape timbers. I'm trying to decide what would be best for the base material. I've read foam, sand, pea rock, and river rock are all used for this. I'd like some opinions on which works best. I've heard there are downsides to each. Foam is expensive. Sand can be washed out easily and it's easily tracked around. Pea rock can be tracked too and if hit by a lawnmower they tend to make good projectiles. Haven't heard really much about river rock. It seems most uncommon. Would probably be lumpy. I do have a Gorilla pad to put between the base material and the pool liner. What do you all think?
