Ball Valve is leaking, anyone have opinions on how to fix or where to buy the valve handle
grey1988
60
Las Vegas/NV
Hi,
I have a ball valve that is leaking. I can get it to reduce leaking down to a trickle but I wanted to know if anyone else has one of these and if they know if the valve handle can be replaced and how? Where to get a replacement? I can almost get it 100% stopped if I turn the valve toward open but then the ball valve will leak a little and the handle will stop leaking. Another option I see if possibly getting a cap to screw on the end and open the valve a little more but I have no idea where to get the end piece to screw on. Any opinions? My pool repair guy was 135 to completely remove it or 350 to replace it and that is not going to happenbv1.jpg.
Thanks in advance
The handle says 1-1/2", but it doesn't look that big. In any case, there is a threaded cap available at Home Depot or Lowe's.
The handle is removable. There should be a screw under the round center red cap.
Maybe try some spray silicone lubricant to see if that helps.
Spray the silicone in the valve and work it in.
Ok, looking closer, it is 1-1/2".
It's glued. So, there's no easy fix.
I would just get a 1.5" threaded cap and keep it capped until you want to use it.
You could get a threaded valve to screw onto the existing threads but that's awkward and it will stick out too far.
Thanks for the help everyone. Per James I tried some wd40 and was able to pull off the little cap and unscrewed the handle and pushed the seal down that was inside and put it back together and does not leak anymore. Awesome!!!!
Reactions: markayash
