This spring we had to redo our 24000 gallons plaster pool (removed all the old plaster, fixed some cracks, re-poured the bond beam, tile, coping, new plaster). After 30 days I installed a SWG chlorinator (Circulpool Universal 40) and added enough salt to get to a 3500 ppm salinity. This measurement is reported by both SWG and a salinity measurement pen like device. I've been in the past following the TFP method without too much stress. I checked the water with test strips, and balanced PH first, chlorine second and didn't worry too much about calcium or CSI. However, with the new pool, I want to make sure I stay on top of all chemicals, to give the plaster a long life. So, I got the TF-100 test kit and started to do daily PH and Chlorine tests, and weekly alkalinity and calcium hardness. I'm struggling a lot with the CYA test, but I'm relatively sure the value is about 60-62. My biggest issue is the PH, I'm having to add muriatic acid every 2 days. I only add 1/2 gallon at one time. I use the HomeDepot HDX brand (14.5% hydrogen chloride). One day my PH would be 7.5, the next is 7.8 and the next one is above 8.0. That's when I add another 1/2 gallon for 2 nights in a row (basically 1 gallon in total) to get it back to 7.5. Alkalinity has been decreasing steadily from 110 to currently 80.
Here are the results of today's tests:
FC: 5
TC: 5
PH: 7.5
TA: 80
CH:400
CYA: 62
SALT: 3500
TEMP: 79.5
CSI: -0.24
According to Pool Math, everything is good (CYA and TA are outside of ideal range, but that's about it). The water looks amazing, perfectly clear and blue.
However, based on experience I know tomorrow PH will be 7.8 and the day after >8.0 if I don't do anything.
I've also heard that new plaster and new SWG will quickly raise PH, but I'm not sure if this is in normal parameters. I'm currently adding 2 gallons of 14.5 muriatic acid to the pool every week.
Also the second part that's confusing for me, lots of non TFP people tell me that my TA is way to low and that's why the quick raises in PH, but Pool Math wants me to lower it more.
Also I've done a test at Leslies, just out of curiosity, and most results came back similar to mine, except they measured the TA at 53 and the CH at 300. I'm trusting my TF-100 kit for now, but I'm a bit confused on why I can't get a handle of my PH and the behavior I'm seeing does in a way match what the "non TFP" workflows suggest, my TA is too low and so I have no PH buffer.
And finally, if this matters, we are in SoCal, the pool is clean, brushed and vacuumed at least weekly.
This PH thing is driving me crazy, any ideas on this forum ?
FC: 5
TC: 5
PH: 7.5
TA: 80
CH:400
CYA: 62
SALT: 3500
TEMP: 79.5
CSI: -0.24
