- Sep 10, 2019
- 89
- Plaster
- Pentair Intellichlor IC-60
Hi all,
Our first pool was finished last spring so this is the first "Texas winter" that I have dealt with pool-wise. I had pretty good success with the pool over the summer, but things seem to be going a bit haywire now that the water temp is dropping. All summer, my numbers looked mostly like this:
Water Temp = 66F
pH = 7.4-7.5 (31% muratic)
ORP = 700 (liquid chlorine)
TA = ~100 (use baking soda)
CH = 200-220 (CaCl2 salt)
CYA = <35
I have an IntelliChem system for pH and ORP (I know that the feeling here about these systems on here, but it works for me ). The system measures LSI and I strived to maintain it as "balanced". My LSI was usually negative, running between -0.3 and 0. As I said, this all worked until water temp dropped. I having a bit of trouble controlling TA (dropping) and CH (dropping) and it seems like I am adding more acid than usual. That makes sense, but I cannot figure out why. It has rained a few times and this is the only thing I can figure out that would be causing it. After each rain, I check the TA and add baking soda but it still seems like it continually drops. I cant figure this one out. I do have a pool filler which is connected to the house supply which runs through the water softener, so if I have a leak there that is the other option. Any ideas?
I am also curious where you recommend to run TA and CH in the colder weather to help prevent the corrosive water. I have been playing with the calculators and it looks like I need to be running my TA and CH on the high side of the ranges (TA = ~120 and CH = 330-350) to keep the water balanced down to ~40F. I am not sure how far the water temps will drop here in Houston, though I cant see it getting much colder than that. My pool will not be covered over the winter. Recommendations?
Water Temp = 66F
CYA = <35
