Hi all,
I have some new stains on the floor of the deep end of my pebble-tec pool. I thought they were created just because I waited a couple minutes before sweeping away the baking soda I had added before adding calcium chloride. But reading through other threads, I wonder now if I added the calcium before sweeping the baking soda, thinking I'd sweep them both at the same time. In any case, the marks are definitely only where the baking soda had collected before sweeping.
Are these stains calcium scaling? Is there any way to remove them without draining the pool? If I do need to drain the pool to remove them, how much should I dilute 31% MA in the solution I use to scrub them off?
Matt
Matt
